Had a simple question
Old Jan 19, 2004 | 05:33 PM
Koji_Si's Avatar
Koji_Si
Default Had a simple question
Im trying to get some Civic type r pistons, but dont know what the difference is in the .25 oversized bore and non oversized. Im trying to put these into my b16 00 Si Motor.
thnx.
Old Jan 19, 2004 | 05:34 PM
Snoopy's Avatar
Snoopy
been there done that
the difference is the .25 oversized is....*gasp*... .25mm bigger than the non oversized.
Old Jan 19, 2004 | 05:37 PM
Koji_Si's Avatar
Koji_Si
i ment difference in regards to, what do i get out of getting that extra .25 bore.
Old Jan 19, 2004 | 05:39 PM
Snoopy's Avatar
Snoopy
well you'd have to re-bore the stock cylinders to get the .25 to fit. so thats one of the advantages, a fresh bore.
Old Jan 19, 2004 | 06:40 PM
PHiZ's Avatar
PHiZ
BOOST GOD
More displacment. They sell a .5 overbore too, I believe.
-PHiZ
Old Jan 19, 2004 | 06:47 PM
Hondaman's Avatar
Hondaman
Black Pearl
-PHiZ
Yup, I have a 305 CI in my Trans Am bored out to a 315 CI.
Interesting fact. In the old John Deere tractors they would bore it out .060", then .120", then resleeve the engine and start with 0 again.
Old Jan 19, 2004 | 06:50 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If your bloack has low miles, there is no scoring on the cylinder walls, etc, you should be able to get away with the stock bore without a problem. If you can afford the down time to have it bored, do it. You'll thank yourself later.
Old Jan 19, 2004 | 07:35 PM
Koji_Si's Avatar
Koji_Si
Will the .25bore give me more power? My engine has 33k miles on it, should i go for the .25bore or no bore for the ctr pistons?
I work for a Honda dealership so if i do anything its pretty much easy to do with help from mechs.
