motor on ground
Old Jan 19, 2004 | 10:12 AM
metalman's Avatar
metalman
Default motor on ground
whats the safest way to lie a motor on the ground? i dont have an engine stand, and i need the picker for another engine. which side is the safest to GENTLY lay it down on?
Old Jan 19, 2004 | 10:21 AM
Hondaman's Avatar
Hondaman
Black Pearl
Set it on an old tire. Your safest bet would be to lay it on the exhaust manifold side.
Old Jan 19, 2004 | 12:27 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Are you on crack? Just set it down flat on the oil pan. I ahve 4 engines in my garage doing just that. And have you ever seen pics of engine supplier's warehouses? Engines sitting on the oil pans....
Old Jan 19, 2004 | 12:52 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
:werd: who the heck would put it on the exhaust manifold side? :screwy:
Old Jan 19, 2004 | 01:00 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
werd we sit all our motors on the oil pan when we pull them.
Old Jan 19, 2004 | 01:09 PM
Hondaman's Avatar
Hondaman
Black Pearl
Why not? It's not going to hurt anything and the center of gravity is lower. It's not like you are going to drag it down the road or something.
I can see two problems with setting it on the oil pan:
1: You can mess up the oil plug bung. If it gets bumped wrong, you can crack the weld and leak oil.
2: The engine can tip over because the center of gravity is higher and fall on the intake/exhast manifold.
Honestly, I don't have a problem with either way. I've just had the best luck laying them down in/on an old tire.
Just my view point. I'm just trying to be helpful.
Old Jan 19, 2004 | 01:20 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
I do agree if you have an old tire it won't hurt anything to sit the motor on it oil pan side down But you never want to set a motor on its side like you said. h:
Old Jan 19, 2004 | 01:25 PM
Hondaman's Avatar
Hondaman
Black Pearl
Ok, thank you. I learned something new today.
Thanks!! :thumbup:
Old Jan 19, 2004 | 04:55 PM
h22avid's Avatar
h22avid
Sleeper...Creeper...
:dunno: I thought you were supposed to balance it on its distributor
Old Jan 19, 2004 | 05:08 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If you lay it down on the exhaust manifold, you are putting pressure on something that is cast steel and the o2 sensor, and putting unneeded stress on the head, h\eadgasket, and head bolts.
What weld are you talking about cracking on the oil pan? The whole pan is stamped steel... And about screwing up the threads, it's never been an issue, plus, if you have the oil plug firmly in place, how can it mess with the threads any worse than if you drove over a stick in the road that hit it?
