quick question about coilover install
Old Jan 17, 2004 | 01:39 PM
angry sol's Avatar
angry sol
Default quick question about coilover install
how do i know which coilovers go in front or the rear? the taller ones or the shorter ones
Old Jan 17, 2004 | 01:48 PM
oc_civic's Avatar
oc_civic
mcc racing
they should have the spring rate marked on them.. i always thought that the stronger ones went in the front.. but there was just a thread a week ago that said the opposite.. so i would say refer to the manufacturer...
Old Jan 17, 2004 | 02:02 PM
oc_civic's Avatar
oc_civic
mcc racing
https://www.honda-acura.net/forums/s...56#post1466556
Old Jan 17, 2004 | 05:17 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
if its the "universal rate" ground controls, the heavier springs go in front. If you ordered custom rates, you should be able to figure it out on your own. If its not GC, then I have no clue.
Old Jan 18, 2004 | 12:48 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
OC is right from EVERYTHING that I've ever seen, and I've had my fair share of different suspension setups. The thicker/stronger springs go in the front. A lot of the time there is a marking on the springs that either says the spring rate, ie: 450, or it will just have an F or R....
Old Jan 18, 2004 | 09:19 AM
white_n_slow
it's my D in a B
the standard civic spring rates for gc are 375f/250r. People (myself included) often custom order a stiffer rear spring rate, but the "stock" setup is 375f/250r. Don't put them on backwards, because 250f/375r is WAY tail-biased, insufficiently supports the front end, and isn't very safe.
Old Jan 18, 2004 | 11:32 AM
angry sol's Avatar
angry sol
thanks for the help.. i kinda was able to figure it out just by looking at the way the coilovers fit with the shocks
