clock problem
there is one right next to the 7.5 which i think is for the ecu since it says ecu. when i did a search about how to fix the clock resetting itself everyone said to replace that fuse. when i checked it, it looked blown to me. it really doesn't make sense to me though. does anyone know any other boards that i should run some searches in for help?
I went through the same thing last year. If the deck is not installed, the clock shouldn't work at all. It's completely normal. But from what you're saying, you definitely have some wire back there shorting out from when your deck was jacked...
