96-00 Rear Disc conversion
Old Jan 14, 2004 | 08:38 PM
bobbybosche's Avatar
bobbybosche
Default 96-00 Rear Disc conversion
All-
Okay I've looked through all the conversion posts already and not really gotten a good straight answer. What year and model parts do I need to do a rear disc conversion for my 99 EX coupe?
And . . . this guy is telling me that the 99 Si front discs are bigger than the EX. Is this true? Are the calipers any bigger? Thanks.
Old Jan 14, 2004 | 08:50 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
You need 94 and up Teg or 99-00 Si rear brakes for the swap.
Old Jan 14, 2004 | 08:53 PM
bobbybosche
don't need the trailing arms or the control arms? please be more specific.
Old Jan 14, 2004 | 09:09 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You don't need control arms, but you do need the trailing arms. Do a search for brake and my name. You will find a lot about it.
hih
Old Jan 14, 2004 | 09:11 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
hih
Correct you need the trailing arms and you may also need a prop. valve off of a 90-93 teg for equal braking. Correct me if I'm wrong WCS.
Old Jan 14, 2004 | 09:15 PM
westcoaststyle
I believe you're right. You should also get a GSR booster and MC. Bumnah may have one for sale.
Old Jan 14, 2004 | 09:22 PM
bobbybosche
Okay this is what I got from the dude for $350 plus shipping. 1999 teg rear trailing arms with all spindles, pads, calipers, slotted discs, e-brake line, all brake lines. Plus front 99 Si font discs all hooked up and complete. And the prop valve from the teg. Now all I need is the booster and mc, right?
Old Jan 14, 2004 | 09:26 PM
westcoaststyle
I believe you need the full front hub to add larger rotors. The caliper has to connect to the hub and if you put larger rotors on, the caliper can no longer bolt on in the OEM position - it will sit further from the hub.
Yes, you'll need that booster and MC for them to work good braking force. PM Bumnah.
Old Jan 14, 2004 | 09:51 PM
bobbybosche
Is this what you mean by full front hub?
Old Jan 14, 2004 | 09:55 PM
westcoaststyle
that would be it. :yes:
