either im a dumba**, or i was screwed.
Originally posted by aenima_20
if you want ppl to help you , get some pics, or find something that looks similiar off the net
Originally posted by Dubs
how can a Triangle and a Square have sex? :dunno:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
OK well for front strut tower bar, you undo the 2 bolts on the side of the strut assembly that are holding it into the chassis. Depending on the bar, you may have to take it out completly or just stick the ends of bar into the 2 screwdriver nut type things, then redo everything. It's hard to explain.
Originally posted by theelnino
http://www.greddy.com/products/produ...roductidx=1680
- it loks the the bar on the bottom of this pic. its a different design, but bolts in the same way this one does
not to be a :boink: or anything
if you dont know how to install a strut bar, its probly pointless of you having it in the car, you should probably invest the $ somewhere else
but thats just my thoughts
good luck
good luck
i dont think it is for the rear either, bc i pulled all the trunk covers out and oculdnt see a spot for it to bolt in. there wasnt a spot under the car either. it is a grex strut bar. thank you guys for putting up with my stupidity
