cel codes
Old Jul 28, 2002 | 09:28 AM
mrmatt421's Avatar
mrmatt421
Default cel codes
how do i read the cel codes i did a search but found nothing...i need to know what the codes mean, sensor wise so i can get my car to run better
Old Jul 28, 2002 | 09:33 AM
crucial Si's Avatar
crucial Si
Banned
if you search you will find old thread that will tell you.
Old Jul 28, 2002 | 09:36 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
what year is your car? I'm assuming it's 92 or newer... Under the glove box, all the way to the side, there is a green cover on 2 plugs. Grab the plug that has two wires in it, throw a paper clip in it to jump the wires, turn the car to on without starting it. Your CEL will flash. Long is a ten, short is a one. So 2 longs and 6 shorts is 26. Then look at the manual and it will tell you what it is...
Old Jul 28, 2002 | 10:07 AM
mrmatt421's Avatar
mrmatt421
its a 96 ex with a b16, the ecu is from the old motor though, i haven't gotten a b16 one yet
Old Jul 28, 2002 | 10:46 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
that's your problem right there, Cheech! Running a sohc ecu on a dohc engine? At least run a b18b ecu on there. That wouldn't have the vtec, but it at least is trying to run something right! Get the ecu ASAP.
Old Jul 28, 2002 | 03:25 PM
crucial Si's Avatar
crucial Si
Banned
you should have gotten a new ecu also, thats a must in a swap like that.
Old Jul 28, 2002 | 04:08 PM
mrmatt421's Avatar
mrmatt421
would that make most of my probles go away?
Old Jul 28, 2002 | 04:14 PM
crucial Si's Avatar
crucial Si
Banned
it will make all of your problems go away.(unless something is really fawked up) your making the car run the way it isnt ment to be run, you cant run a sohc ecu on a dohc motor, makes sence huh? look on ebay they are pretty cheap.
what code are you throwing?
Old Jul 28, 2002 | 04:15 PM
mrmatt421's Avatar
mrmatt421
don't know i gotta read them tommorrow, but i'll put them up
Old Jul 28, 2002 | 08:19 PM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
you can jump it alllll nnnnight longggg!
greengsr2k
3
Aug 15, 2004 08:28 PM
crucial Si
92+ Civic/EL & Del Sol
6
May 7, 2003 02:04 PM
OneToughCivic
19
Sep 25, 2002 08:54 PM
long
Engine Swaps, Tech & Tuning
Sep 11, 2002 02:01 PM
