HB/Coupé front bumper on Sedan?
Old Dec 26, 2003 | 02:20 PM
loodboi's Avatar
loodboi
هونده بريلود
Default HB/Coupé front bumper on Sedan?
Is it hard to fit an HB/Coupé front on the Sedan? I guess MaxBoosT have done it?
What is the difference between those bumpers? sedan bumper wider?
Old Dec 26, 2003 | 03:37 PM
EJcivic02's Avatar
EJcivic02
I talk Before I think
Default Re: HB/Coupé front bumper on Sedan?
PM maxboost or cashis, they both have done the 2/3dr front end on a 4dr. From what i remember, i think you need the fenders, bumper, and corner lights.
Old Dec 26, 2003 | 04:42 PM
Wharbone's Avatar
Wharbone
search
You just need the bumper and corner lights from a 2/3 door. Then I believe you have to dremel your own holes on the bumper.
Old Dec 27, 2003 | 11:18 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Sasbonian (sp) has done this too... search is the key.
Old Dec 27, 2003 | 12:23 PM
loodboi's Avatar
loodboi
هونده بريلود
But the question is, isnt the front bumper in the hatch wider than the sedan one?
Old Dec 27, 2003 | 06:16 PM
westcoaststyle
ASK SOMEONE THAT'S DONE IT... like the 3 that were listed. h:
MaxBoosT, Sasbonian, Cashis EG8
Old Dec 28, 2003 | 06:21 AM
mood's Avatar
mood
I think the OEM 92-95 Honda Civic sedan front bumper is actually a tad bit wider than the OEM hatch/coupe front bumper. I had to pull the sides out a little when I installed one a while ago. Since the OEMs are made of urethane, it's not hard to get the coupe bumper to fit on the sedan. Just remove the plastic piece that holds the screw in place on the fenders and use a bolt/washer/nut combination instead. That will hold the side of the bumper to the fender more securely. Once you get the sides bolted in, it helps to use a heat gun to help massage the bumper into place. The lines won't be perfect but it will look like it was supposed to be there to the untrained eye. You will need to trim around the corner light area to get the corner lights to fit. Some say to use the coupe/hatch corner lights, I was able to use my sedan corner lights.
This also applies to the aftermarket bumpers that other companies sell for the 92-95 Civic coupe. I have installed the Wings West Bigmouth and the Avenger front bumper on my sedan before using the bolt/washer/nut combo and used my sedan corner lights as well..
Old old pic of my sedan....
Old Dec 28, 2003 | 06:31 AM
loodboi's Avatar
loodboi
هونده بريلود
^ Thanx man!
