Need Help: Doors Rattling
Old Dec 24, 2003 | 12:47 PM
  #51
dawrenn's Avatar
dawrenn
On my head unit there is a setting that is called Equializer curves, It has low, medium, and high. I was wondering if that would also cause the speakers to blow? I have my low set on +3, my medium set on +2 and my high set on +2. I know this probably means nothing to anybody but someone might know or have the same head unit I do.
Old Dec 24, 2003 | 08:11 PM
  #52
habitatsk8r392's Avatar
habitatsk8r392
Certified Ricer
wait what kinda head unit is this??
Old Dec 25, 2003 | 02:49 AM
  #53
SpeddyDOHC's Avatar
SpeddyDOHC
Originally posted by supermac88
It could be you had your bass turned up to high on you mids, that would cause them to blow fairly quickly just a thought, I run my loud feature on med. and I have no problem with my 2 speakers blowing
Someone told me that having the bass turned up high would not cause the speakers to blow.
Old Dec 25, 2003 | 02:59 AM
  #54
SpeddyDOHC's Avatar
SpeddyDOHC
Originally posted by Kestrel
Don't know if this will help you, but when I was helping my friend install upgraded speakers and a sub on his 2.5RS we stuffed his trunk lid and the area around the door speakers with mattress stuffing, and his car does not rattle. Just be careful about the windows and lock mechanisms and stuff
That's a good idea :thumbup:
Old Dec 25, 2003 | 03:11 AM
  #55
dawrenn's Avatar
dawrenn
Head Unit
I just want to know what the settings should be at. I don't want my speakers to blow, People say that distortion blow speakers which is true but I want to have the settings correct.
Old Dec 26, 2003 | 11:13 AM
  #56
dawrenn's Avatar
dawrenn
I have mine set at 1 cause my subs have plenty of bass just try it you might be surprised how much cleaner your music sounds.
I am going to have to turn my bass down even more b/c I can tell that I am losing my hearing a little bit from too much bass :wtc:
Old Dec 27, 2003 | 05:30 AM
  #57
dawrenn's Avatar
dawrenn
What is clipping and how does it happen?
Old Dec 27, 2003 | 07:23 AM
  #58
elimor_4's Avatar
elimor_4
hey I have eclipses and they are great, never had a problem with them Recommended.
Old Dec 27, 2003 | 07:44 AM
  #59
igo4bmx's Avatar
igo4bmx
CockBlockerator
alright i'll help ya :bigok:
first, take off your door panels, inspect the plastic rivets and make sure they look fine... it helps to replace them with brand new ones because they stretch out and make the door panel loose.
i took mydoor panels off and tightened every screw in there.
second get yourself sounddampening material
dynamat is nice but you can get other shit for cheaper like Raamat (which i used :bigok: ) brown bread, fat mat,
third fill the upper trunk lid up with foam from home depot its called "foam insulating spray" and its in a blue can
fill up the trunk lid with it ... let it dry then cover the lid with sound dampening material. you can do this with other places like the ine rear quart panels too
Old Dec 27, 2003 | 07:45 AM
  #60
igo4bmx's Avatar
igo4bmx
CockBlockerator
here is my setup right now
pioneer premier p940mp
jl XR 6.5 comps in front
no rears :bigok:
2 12 inch alpine type Rs
clarion DPX 1000.2
nakamichi PA-504
