how do i take out my a/c......
i dont know the exact term for it but the part w/ the fins and sh!t....i want to take it out to fix all the bent fins. what do i need to take off b4 i do this, my a/c doesnt have any freon in it so dont worry about that. thanks
Originally posted by C-West EK
first take off all of the a/c lines...then remove the brackets that hold up the fan..should be another few 10mm bolts above the fan and below it
yeah disconnect them from the compressor so that the a/c lines hang freely in the engine bay...its the easiest way to remove the a/c fan if that is all you plan on doing
KiMBO's Hubby
the two a/c lines from the top, which run along the side of your condensor and goes into the compressor can be disconnected with a crescent wrench or the proper fitting wrench. after that, disconnect the plug on the right side of that fan along with the four 10mm bolts holding in the fan. btw, how did the fins get bent?
it got bent from rock and debris hitting it i guess. my old radiator looked like that too but i had to replace that though.
