How much should this work cost?
Old Dec 17, 2003 | 11:54 PM
dlh1999's Avatar
dlh1999
Runs with scissors.
Default How much should this work cost?
I searched the forum, but couldn't find a satisfactory answer. So here's the deal...I need to get my timing belt & water pump replaced, and unfortunately I really don't have the time to do it myself. The dealership said the job would be $400 or so, but that seems just a bit high. Any ideas? Also, is there anything else I should get done on my car while it's in the shop (valves, etc)?
BTW, it's a '97 HX...thanks.
Old Dec 18, 2003 | 12:08 AM
Tirod's Avatar
Tirod
i got water pump, all belts, new head gasket (of course) for 350 at an independant honda only shop... check yer yellow pages for one of those.. they are usually owned by ex honda techs that only use genuine honda parts w/o the dealershp prices
Old Dec 18, 2003 | 12:56 AM
dlh1999's Avatar
dlh1999
Runs with scissors.
That sounds a bit better...I'll make sure to check around a bit. Like I said, I figured that was just a bit high. Thanks for the reply.
Old Dec 18, 2003 | 01:05 AM
frank's Avatar
frank
frank from canada
i got mine done for 250 Canadian, how it broke down was about 55 for the pump, and 45 for the belt, and 150 for the labour. they do a quality job and its one of those places you can trust.
Old Dec 18, 2003 | 08:16 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
It shouldn't be much more than if you were to just change the timing belt. The water pump is right there when you do it. All you have to do is take out 4 more bolts.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Dec 18, 2003 | 08:38 AM
patrickd's Avatar
patrickd
$400 sounds cheap to me for a Honda dealership to do it. You want to make sure the techs know what they are doing. A dealer quoted one of my friends over $700 for the timing belt change. The cost is almost all labor.
Old Dec 19, 2003 | 12:04 AM
dlh1999's Avatar
dlh1999
Runs with scissors.
Thanks for the input. I'll keep looking around...I'm hoping to get the work done next month.
