90,000 miles.. what would be main things to change and replace..?
Old Dec 17, 2003 | 11:09 AM
honda1998civic's Avatar
honda1998civic
Default 90,000 miles.. what would be main things to change and replace..?
i have 90,000 miles on my 98 civic... What did you guys notice that needed to be replaced or changed on your cars? Just looking for some tips... thanks....
Old Dec 17, 2003 | 11:45 AM
Nelson's Avatar
Nelson
Administrator
Definitely spark plugs, check tires, check cv joints...
Timing belt, water pump, thermostat wouldn't hurt...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Dec 17, 2003 | 12:16 PM
mitsurugi's Avatar
mitsurugi
Super Member
I agree. To add to that I'd say change the tranny fluid if you haven't lately.
Also, it wouldn't hurt to replace the blinker fluid and the muffler bearings. :rick:
Old Dec 17, 2003 | 12:45 PM
Wharbone's Avatar
Wharbone
Default Re: 90,000 miles.. what would be main things to change and replace..?
You asked the same thing here, and it was explained well. I took the time to copy what my service manual said, and you should follow it. You should do everything the service manual says.
https://www.honda-acura.net/forums/s...ighlight=miles
Old Dec 17, 2003 | 12:49 PM
Wharbone's Avatar
Wharbone
to reiterate what I said in the other post,
Originally posted by Wharbone
According to the 92 service manual:
-Air cleaner element - Replace
-Valve clearance - Inspect
-Fuel line connections - Inspect
-Spark Plugs - Replace
-Engine Oil - Replace
-Engine oil filter - Replace
-Alternator drive belt - Inspect
-Power steering pump belt - Inspect
-Cooling system hoses and connections - Inspect
-Manual transmission oil - Replace
-Automatic transmission oil - Replace
-Timing Belt - Replace
-Water pump - Inspect (might as well replace this at the same time as timing belt)
-Exhaust pipe and muffler - Inspect
-Front brake pads - Inspect
-Front brake discs and calipers - Inspect
-Rear brake discs, calipers and pads - Inspect
-Rear brake drums, wheel cylinders and linings - Inspect
-Brake hoses and lines (including abs) - Inspect
-Parking brake - Inspect
-Brake fluid (including abs) - Replace
-ABS system - Inspect
-Front Wheel alignment - Inspect
-Steering operation, tie rod ends, steering gearbox and boots - Inspect
-Power steering system - Inspect
-Suspension Mounting bolts - Inspect
Old Dec 17, 2003 | 02:00 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
pretty much everything that requires to be.
Old Dec 17, 2003 | 07:44 PM
honda1998civic
ok.. just wanted a clearer answer.. last post everyone was saying different things... thanks again..
