DIY: The POLISHING
It's a good idea to have a valve cover gasket kit around just in case you do. The Viton® gasket becomes brittle over time from the heat and petroleum exposure, and eventually it won't be reusable. But if you're not leaking oil now, and there aren't a ton of miles on the car, you can usually clean it up and reuse it without any problems. Just put black silicone on any corner or seam in the seal when you re-install it.
The valve cover gasket kit will come with new sparkplug o-rings, and valve cover fastener grommets. They're usually pretty cheap, and if you're going through all the trouble of polishing a valve cover, a new gasket might well be in order.
If your valve cover is coated with one of Honda's lovely black or red finishes, you're going to hate stripping it, but it can be done. You're better off buying a bare one from eBaY and polishing that one instead. For instance... my CX's valve cover was black... a '93 non-VTEC Del Sol's valve cover is bare aluminum. I bought it for $10.50, and polished it while keeping the car in service. It took me a week to finish it, and 2 days to polish it.
Jafro-
Thanks for the awesome post, that helped me out a lot
What is the Viton gasket, is that the stock one? Also, my car has 80k on it, so I'm just going to replace it anyway to be safe.
How long do you think it would usually take to polish the valve cover. I'm assuming I start with low grit, then work up to high grit, then hit the polishing wheels? Also, I think that my valve cover is just the bare aluminum. Here is a pic
What is the Viton gasket, is that the stock one? Also, my car has 80k on it, so I'm just going to replace it anyway to be safe.How long do you think it would usually take to polish the valve cover. I'm assuming I start with low grit, then work up to high grit, then hit the polishing wheels? Also, I think that my valve cover is just the bare aluminum. Here is a pic
Originally posted by Jafro
...also be warned... BEAD BLASTING IS BAD on ANY part that used to, or will eventually contain motor OIL. Glass beads are nearly indestructable, and they stick to oil. All that oil has to do is eventually get pumped through the engine into a bearing surface and you're engine is fawked. Of course, you can hot-tank the part, and then blow it out with compressed air... but that would still scare the hell out of me if I bought HKS cams, forged rods and pistons, and $1500 worth of machine work.
Solution: if you're going to blast something, use walnut shells on any engine parts that will contain oil. Walnut shells are oil soluable, so they won't eat bearings if you don't manage to clean that one little tiny piece of it out of the part.
i've seen pictures of ampliers bead blasted and they are shiny as hell.
there are different "levels" of beadblasting from what i learned
Start with 220 until you've stripped EVERYTHING that you don't want showing on the finish. Then use 320, 400, 600, and finally 800 before polishing. You want to spend at least 4 hours with each grit, or until imperfections are gone. You also want to sand in the same direction once you're finished with 220grit. The polishing wheels won't remove ANY scratches, chips or pits in the finish, that's up to you and however much time you spend sanding.
Originally posted by igo4bmx
your beatblasted block does not look shiny at all!
Billett aluminum (like your fuel rail) can be polished without all the sanding. Anything that's made from billett will turn out great with very little work because billett stock isn't porous like cast stuff is.
About a week if you spend 4-5 hours a day on it.
Here's a potentially really dumb question: Do I have to remove the valve cover to polish it, or can I do some of it while it's on. This is my daily and only driver, so I'd rather not have it down for a whole week.
Man... I couldn't imagine doing that. Yes, you could, but the metal shavings will be stuck all over everything in your engine bay when you're done.
Why don't you buy a valve cover off of eBaY like I suggested? Those things go for dirt cheap. That way you can polish it, install it when you're done with a new valve cover gasket kit, and be done with it without the mess. If you haven't polished anything before, I definitely don't suggest you try it while the part is on the car.
