Hybrid Forum FAQ
Old Jul 26, 2002 | 06:09 AM
white lightnin's Avatar
white lightnin
Default Hybrid Forum FAQ
As some of you may have noticed the Hybrid forum here is pretty dead. We thought maybe a FAQ could revive things. I have come up with a list of stuff that applies to Hybrids plus a few other things. Put down your answers and I will compile everyones input. Then post it back up for final editing. Thanks guys.
-Which motors go into which cars?
-What do the motor codes stand for?
-What seats will fit in my car?
-What do I need to run A/C or Power Steering?
-What wiring is required for differnet motors, years, etc?
-Do I need a mount kit?
-How do I swap X front end onto Y car?
-How do I swap X brakes onto Y car?
-Good suspension setups w/ different engines and chassis?
-What do the different chassis codes stand for?
-What JDM parts will bolt in/on so I can be cool?
-What gauge clusters will bolt in? and how can I wire up differnet ones?
-How do I modify my exhaust for different setups?
-Engine building tips for different setups NA, turbo, nitrous etc.
- How much Boost/ Nitrous can I run safely stock?
Thats a bunch, but Im sure there are more. Add anything you can think of. Thanks, Robert.:thumbup:
Old Jul 26, 2002 | 06:47 AM
Nelson's Avatar
Nelson
Administrator
I'm no expert, there's some guys in the clubsi forum that are guru's, so I suggest asking them for detailed explanations... here's just a few quick answers I learned while researrching my motor.
Any Integra and Civic (D, B-Series) engine is virtually interchangeable. Even the Prelude H22.
Example: B16A B= The Series (D,B,H,K,F,etc) and the numerals usually refer to the displacement in liters. 16 = 1.6, 18=1.8, etc.
If you're running a Civic, any Del Sol, Civic, or Integra seats will bolt right in without major modification (of any)... that's for the fronts... The rears, however are a little more hairy.
If you are swapping, and your car already has A/C & P/S, you'll might just need new brackets.
Depending on the ECU-- ODB1, ODB2, Pre-ODB, might need conversions.
Yes and no, some people run GS-R ones and are fine. Others prefer the stronger stiffer racing type ones, for drag-racing much movement is undesired, I chose to run with GS-R ones because I'd rather have quiter less chatter.
Civics, 92-95-EG, EG6 is Hatch I believe, EG8 & EG9 are sedan, that's all I know off top of my head.
Eh...
Not a big fan of NO2, so IMHO, I'd rather not.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jul 26, 2002 | 06:48 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Good idea White Lightnin
Old Jul 26, 2002 | 09:14 AM
white lightnin
Just thought of some more that I wasnt sure on:
-When do the OBD's change, what about in Japan?
-Differences in Later Model H22's
-More Exotic F and H series engines
LT
Jul 8, 2006 10:10 AM
SUPER LAUBO
Dec 23, 2003 03:03 PM
white lightnin
Jul 28, 2002 08:32 AM
white lightnin
Accord
Jul 26, 2002 09:15 AM
