Changed rims and tires... and gas mileage way DOWN
Hey, I was wondering if this seems right.
On my 6th gen EX, I had 14" steelies running Yokohama 195/55/14. I used to get like 32 mpg if I don't drive hard.
I bought some dudes Si 15" OEM alloys which had Falken 195/50/15 on them. The tires were bad so I bought new Yokohama AVS ES100 tires 195/50/15.
Suddenly my gas mileage is like 27 mpg. What the heck?
Ok, I know that the circumference of the 14" was smaller than the 15" by about 1% (odometer not changed). The alloy rims are supposedly lighter than the steelies, and I didn't think the new Yoko's are that much heavier than the old ones. Does -5 mpg sound right? This sucks. I'm not even driving it hard.
As far as alignment goes, when I bought the tires the company that sold and mounted them also did an alignement... so supposedly my alignement is now "better".
As far as air pressure goes, the 14" was at 30/29 psi and now the 15" is at 33/32 psi.
Nothing else has changed. Driving conditions the same, everything.
This is really wierd. (and unnecessarily expensive)
I'd say alignment since that's what changed and can really effect something like that. If your toe-in/toe-out is off then you're working against the tires when you drive, causing your motor to work harder and use more gas. That's my diagnosis.
h:
