Brake rotor
Old Dec 12, 2003 | 12:35 AM
kerokeron's Avatar
kerokeron
Default Brake rotor
Does brake rotor (front) from CRX si fits to del sol si model?
Old Dec 12, 2003 | 06:10 AM
sxecrow's Avatar
sxecrow
Banned
what size is the rotor on the CRX? I believe they would fit, however the rear is different. Bakeoff or OSX can confirm.
Old Dec 12, 2003 | 03:13 PM
kerokeron's Avatar
kerokeron
Thanks,
I will take the tires and check the size.
I dont have problems on the rear. besides, my crx has drums on the rear. del sol are four disk brakes.
Thank you for you help.
Old Dec 12, 2003 | 03:50 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
not all sols had rear disks!
If you're swapping the front rotors from an S, yes it will work, not sure if the Si's had bigger brakes than the S... Check the part numbers on www.hondaautomotiveparts.com
Old Dec 12, 2003 | 04:24 PM
sxecrow's Avatar
sxecrow
Banned
Si has disks :doh:
Old Dec 12, 2003 | 08:45 PM
OSX2000's Avatar
OSX2000
Do what must be done.
Front rotors aren't the same size for all del Sols. S had rear drums, Si and VTEC had rear disks.
Old Dec 12, 2003 | 08:47 PM
rtpassini's Avatar
rtpassini
but the vtecs have different size ones.
Old Dec 12, 2003 | 09:29 PM
OSX2000's Avatar
OSX2000
Exactly...VTEC fronts are 10.3" in diameter, S and Si fronts are 9.4".
Old Dec 12, 2003 | 10:55 PM
Motohip's Avatar
Motohip
Hmmm...is one inch that much of a diff? That would be a cheap upgrade. Dontcha think? :dunno:
Old Dec 13, 2003 | 01:26 AM
OSX2000's Avatar
OSX2000
Don't matter to me, I'm gonna get slotted rotors anyways... :boink:
