short shifter bushings
Old Dec 9, 2003 | 06:41 AM
riceman643's Avatar
riceman643
Default short shifter bushings
what happens if i install my short shifter without replace the stock bushings?
Old Dec 9, 2003 | 06:42 AM
Daniel's Avatar
Daniel
Then you have a short shifter with stock bushings.
Nothing wrong with that.
Old Dec 9, 2003 | 06:48 AM
riceman643's Avatar
riceman643
do you think some energy suspension bushings would make a big difference?
Old Dec 9, 2003 | 07:16 AM
NoRiCeHeRe's Avatar
NoRiCeHeRe
:lmao::werd:
Most would suggest to you to replace the stock bushings with the polyuthrane (sp) bushing. From what I have been told iif you get the poly bushing makes the shift smoother. So it won't hurt anything if you have the stock bushings in.
Old Dec 9, 2003 | 08:17 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
They won't make a big difference but they will help in the long run. Usually they will last longer and I'm guessing that the stock shifter has a few miles on it and could use a new set of bushings anyway. Also, check and see if the boot is okay that goes over the bottom of it. You don't want road salt or water to get up in there.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
