What kind of power would this put out?
Old Dec 3, 2003 | 05:13 PM
donkiman's Avatar
donkiman
Default What kind of power would this put out?
I know the b20b comes with around 130hp. I was wondering what one fully built like this would put out? and also if anyone has turbo'd a b20 how do you like it? and after tuning how much power does it put out with the turbo.
Block is bored over to 84.5 mm. Components are as follows: 97 crv block (b20b)28,000 miles on block 2000 GSR head, only 9,000 miles 1999 GSR Transmission, 13,000 miles, very clean, no grinds JE 12.1:1 compression pistons ACT 6 puck clutch and heavy duty pressure plate Skunk 2 intake manifold Skunk 2 cam gears CTR intake cam RC 310 cc injectors AEM fuel rail B&M fuel regulator GSR shift linkage Skunk 2 Short shifter New T belt New Water pump New Oil pump GSR ECU All sensors All mounts for either 92-95 civic 96-00 civic or 94-00 integra New GSR axles Compression and leak down tested Machine work is as follows: Block bored to 84.5 mm and honed Rods were bushinged to allow for wristpin float Block hot tanked All new bearings (all were plastigauged)
Old Dec 3, 2003 | 05:40 PM
Paulll's Avatar
Paulll
Hail Bent
12.1:1 and turbo ?
Old Dec 3, 2003 | 09:16 PM
incublinkus's Avatar
incublinkus
JDM Fan Boy
N/A, if everything was tuned properly you'd could prolly see anywhere from 190-230 whp with a nice exhuast and header
Turbo, if you drop the compression and consider having it sleeved, the sky is the limit basically.
Old Dec 4, 2003 | 07:09 AM
1fastercrx's Avatar
1fastercrx
What the hell, TURBO.....12.1:1????
Are you Crazy???
Running all Motor with what you said you can expect about 210 hp and 160-170 ft-lbs of torque.
Old Dec 4, 2003 | 08:51 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
after your turbo = 0 hp
turbo and high compression = :nono:
read the detonation thread, it has good info. :thumbup:
Old Dec 4, 2003 | 03:41 PM
donkiman's Avatar
donkiman
hahaha no no i wouldnt turbo it with 12.1 compression. I was wondering what that kind of power that would put out because I could buy one built like that. then when I put a turbo on it I would change the pistons to prolly around 9.1:1 or so.
Old Dec 4, 2003 | 03:45 PM
donkiman's Avatar
donkiman
You guys are all saying it would put a little over 200. That seems like alot to me considering it comes stock with 127. I know tuning does alot but can tuning, new pistons, cams, IM, and cam gears, header, and exhaust. make 70 hp?
I'm not critisizing your judgment I'm just trying to better understand this B20. It's new to me.
Old Dec 4, 2003 | 03:58 PM
Civic2Scooby's Avatar
Civic2Scooby
all things listed...plus 12.1 compression and being a cr/vtec...70hp isnt such an outlandish number
Old Dec 4, 2003 | 04:35 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Why do all that and use ****ing ctr cams?
Old Dec 4, 2003 | 08:41 PM
niko's Avatar
niko
Im driving a f_cking egg
I agree. He would make so much more power with harsher racing cams or something.
