What would I run?
Old Dec 2, 2003 | 03:05 PM
  #41
EJcivic02's Avatar
EJcivic02
I talk Before I think
Originally posted by kittykat
it's a manual...I'm not going to proclaim that I'm a great driver...but, I'm not too shabby for a geeky girl...I go for the sleeper look:thumbup:
you go for the sleeper look? :eh: IF you're referring to your car, then ya've got the wrong idea, theres nothing sleeper about it.
like everyone else has already mentioned, dont bother stripping out the interior, wont result and in any drastic changes. Just go and have fun. :thumbup:
WCS: whats the drawback to having the cam cover off and not having a hose connected from the intake to the valve cover?
Old Dec 2, 2003 | 03:23 PM
  #42
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Don't even worry about it. IMO the car looks nice, just get it painted and it's all good. If you like it, that's all that matters, if you're not worry about making it a speed demon, keep the interior in. As for the 1/4 times it should do somewhere around 16's.
Old Dec 2, 2003 | 03:33 PM
  #43
Paulll's Avatar
Paulll
Hail Bent
poor car,
id say a 16
Old Dec 2, 2003 | 04:41 PM
  #44
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I've been searching for about 10 minutes now but can't find what I'm looking for.
A while back someone posted a link to a thread where a guy had no cam cover on his DOHC motor. He was pointing at them and talking to a friend when he accidentally stuck his finger between the gears.
It ALMOST ripped his finger off and actually caused the motor to stop.
That's one reason.
The other is that it is possible for a rock or some type of debris to get into your engine bay and drop into your lower cam cover... it would destroy your timing belt if it hit just right and could bend your valves... over a cam cover and a little rock. :doh: That would ruin my day.
The cover was made for the engine for a reason. Use it.
Old Dec 2, 2003 | 05:24 PM
  #45
EJcivic02's Avatar
EJcivic02
That's one reason.
i figured thats what the purpose of it was, not like im planning on taking mine off anytime soon, nothin to show off or prove with a stock single banger
what about the intake to valve cover hose?
Old Dec 2, 2003 | 06:06 PM
  #46
Snoopy's Avatar
Snoopy
been there done that
Snoopy: FINALLY!! I was waiting for you to make something like that.. haha!
i made it like 2 months ago. not many chances to use it. h: :chuckles:
Old Dec 2, 2003 | 06:09 PM
  #47
The G2 Racer's Avatar
The G2 Racer
Want Boost!
WCS: What about those half moon cuts in the valve cover to get at your cam gears for tuning. Those ok or not?
Old Dec 2, 2003 | 09:13 PM
  #48
westcoaststyle
I read a lot about that kind of thing when I was researching the oil catch can. I saw that people were saying that the piston rings don't seal correctly when you don't have that breather hooked up. It also does not allow for correct vacuum pressure within the engine (from my reading). I guess it all comes down to why? If you can get a little hose that was originally part of the OEM design, why wouldn't you? Some engineer in Japan decided that it was a good idea to add that hose, why should we argue with him? h:
Old Dec 2, 2003 | 09:15 PM
  #49
westcoaststyle
I say no for those as well. Still allows for the same problems I mentioned before. How often will you really need to adjust cam gear? So unoften that you could remove your valve cover and the upper timing cover to make the adjustment and reinstall the cover.
It's a mod for looks, not for usage.
It's jmo, but I think that it brings a reality to the situation.
Old Dec 3, 2003 | 11:45 AM
  #50
dbrummet's Avatar
dbrummet
GIT-R-DUN!!!
I used to have the same setup (with y8) with the cheapo intake with the hose off and it sucked on both bottom and top end...bottom end was caused from the hose and the mid and top were from intake...best thing to do is get rid of intake and get an AEM...HUGE difference especially with the HEADER...and EXHAUST...heh
