Tons of pics... Osaka thread, etc.
ill hook it up with more conversion pics tomorrow... this engines gonna get built up before it goes in... and it's going in my brothers hatch he left here for me when he moved to cali...
Hopefully the sensor is still useable but it may need replaced. You may have to replace the entire throttle body as Honda only sells new TPS that's way, but I've heard of people using a dremel on the studs and remove the sensor and replacing it. Takes a little work to get it perfect though.
Not sure what the plug you had was for? Need to check everything a little closer but it might be capped off? Nice on the LSD tranny. Did you get new axles too?
Im gonna see what I can do about the sensor... people told me to dremel the brackets.
dremel the bolts. In theory you can dremel a slot into those bolts holding it to the TB and use a flathead screwdriver to remove it. You can then do the same with another TPS and swtich them and secure it with regular screws. I've heard issue with bad idle and engine response though after swtiching sensors. Might be the sensor needs to be aligned or possibly people just damage the TB gasket and never fix it (be suprised how many bad idles are caused by that).
