Inside Door Latch
Old Nov 30, 2003 | 08:30 AM
ExiledinIN's Avatar
ExiledinIN
Default Inside Door Latch
Anyone tried taking the inside door latch out? If so, do you need to bend the rod down on the switch and the handle (94 EX Coupe).
Old Nov 30, 2003 | 08:41 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
Old Nov 30, 2003 | 09:20 AM
Wharbone's Avatar
Wharbone
the rod attatches to the the handle. There is just a hole in the plastic on the handle that the end of the rod slides into. I am unclear on what you are asking. You don't need to bend anything.
Old Nov 30, 2003 | 11:11 AM
ExiledinIN's Avatar
ExiledinIN
The latch itself. You just have to pull the black pin, and then slide the latch off. Is that right?
However, I'm not sure how to get the lever off. This is what I'm calling the lever:
The backside the lever is held in by the rod. The rod is U bent. Can you just slide it off???
Old Nov 30, 2003 | 12:00 PM
Wharbone's Avatar
Wharbone
pull up on the rod, and it should slide out of the lever. Your handle is different than my 92 ex sedan.
Old Nov 30, 2003 | 12:52 PM
ExiledinIN's Avatar
ExiledinIN
Can't really pull up. The rod is U shaped around the hole on the lever. Do I bend the rod so that I can pull up?
Old Nov 30, 2003 | 06:34 PM
ExiledinIN's Avatar
ExiledinIN
ttt
Old Dec 1, 2003 | 04:46 AM
Wharbone's Avatar
Wharbone
on mine, there is also a plastic clip that holds the rod down that needed to be taken off.
