Got a 95 Civic DX Coupe..possible turbo kits?
Originally posted by westcoaststyle
check out www.bseries.net for more info on the trannys.
If it comes with all of the stock mounts, you will be fine (unless you have A/C and want to keep it).
Hmotorsonline has a very good rep out here. They'll treat you right.
well i want A/C so what mounts do i have to change the one from the del sol vtec? even though im not getting a vtec motor?
The P52 del sol mount has the correct bolt pattern to fit the motor and bolt to the mount on the unibody. It also has the same pattern that your A/C compressor has so you can mount it up...
In fact... now that I think about it. I have this mount and I don't need it anymore since I removed my A/C. If you wanna trade me your mount and a couple bucks, I might be able to work that out.
Lemme know...
Lemme know...
