did 5th gen ex's come with rear disks?
Old Nov 25, 2003 | 02:43 AM
agent87's Avatar
agent87
Need zzzzz's
Originally posted by Wharbone
my 92 ex sedan has rear discs
:wavey: Same here.
Originally posted by e30dood
Drums actually stop better but since they can't dissipate heat as quickly as discs so they suck. h:
In other words, they just suck. h:
Dood, watch Tiff Needel clown on them in the latest Fifth Gear episode!
Originally posted by Outxider
in that case i wanna do a front drum conversion and crossdrilled some holes.
:lmao:
Old Nov 25, 2003 | 04:49 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
as stated before
most of the Si's had disks, some of the very early 92's, and some of the 95's didn't have ABS... they moved the use of the ABS unit to the 94+ Teg
MOST EX coupes that have disks have ABS. Disks/ABS were an option, however a few slipped through that had rear disks w/o ABS
MOST EX sedans have reardisk
Old Nov 25, 2003 | 10:01 AM
wilsel's Avatar
wilsel
Not if you have the right proportioning valve.
If you swap the MS/Booster, and prop valve you get more balanced braking than original equip.
Old Nov 25, 2003 | 10:43 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
The cool thing about drums is they lock up easier, which makes they rallying alot more fun. No more rallying for me
Old Nov 26, 2003 | 05:32 AM
ExiledinIN's Avatar
ExiledinIN
So if I do a gsr conversion, can I still use my Skunk2 coilovers and Koni shocks?
Old Nov 26, 2003 | 06:31 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Yes, you can reuse your EG LCAs cause most conversion don't come with them. It's usually just the trailing arm and hub assembly.
DC and EG LCAs are the same anyway (save for the sway bar mounting on some).
hih
Old Nov 26, 2003 | 06:32 AM
h22avid's Avatar
h22avid
Sleeper...Creeper...
Yes you can, the strut's are identical between the integra and the civic.
Old Nov 26, 2003 | 06:37 AM
westcoaststyle
not with the ITRs h:
Old Nov 27, 2003 | 06:38 PM
h22avid's Avatar
h22avid
smart ass... you think you're soooo smart h:
