Steering Wheel Shake
Whenever i drive, my steering wheel will shake, and it's variable to the tires rotation, it's a odd type of shaking...like it'll turn a little bit, the re-adjust itself probably once or twice a rotation...I know it's not the rotors, so could it be just a unstable wheel?
you might want to re-balance the wheels if it's not the rotors. also check the alignment and the treadwear of your tires. also make sure you lugnuts are tightened to torque specs.
If it's when your slowing down, your rotors have probably warped and either need shaved or replaced. If you only really notice it as the speed goes up, you probably need your wheels balanced or you alighnment is out of spec.
