Fuel pressure regulator?
Old Nov 21, 2003 | 07:29 AM
Slacker's Avatar
Slacker
Default Fuel pressure regulator?
Ok so I finally started working on my ride again. My goal is to fix this running rich/hesitation issue you all prob know about already. Anyhow, I bought new injectors and a fuel pressure regulator. My questions... What is the correct fuel pressure for a jdm b18c? And how do I adjust the B&M fpr? I mean I know how to adjust the fpr, but how do I verify I'm running the right pressure? Do I need a fuel pressure gauge as well? Or can I go by sight, sound, something else?
Old Nov 21, 2003 | 07:43 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
I don't know the fuel pressure for the b18c, but you should use a gauge.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Nov 21, 2003 | 07:57 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You need the gauge...
I run between 40 and 50 psi. I think it was at 42 or 46 before I put the turbo on.
hih
Old Nov 21, 2003 | 08:02 AM
Slacker's Avatar
Slacker
Thanks guys. I guess I will pick up the B&M gauge tonight and just put it under my hood for now. Until I turbo the motor I don't see a need for any gauges in the actual car yet. I got the fpr for $53. And the gauge is like $25. Pretty sweet deal I think. How do you feel about the B&M fpr? Good choice?
Old Nov 21, 2003 | 08:11 AM
westcoaststyle
It's ok. I have that too... I don't like the adjustment on it cause my Neuspeed STB gets right in the way.
I haven't had a major problem with it yet though.
Old Nov 21, 2003 | 08:13 AM
Slacker's Avatar
Slacker
Sweet! It's called like a commando or something like that. Guessing theya re all the same. Now I just have to figure out where to put the gauge....
Old Nov 21, 2003 | 08:29 AM
oc_civic's Avatar
oc_civic
mcc racing
i prefer my autometer IN CAR fuel pressure gauge with isolator.. as compared to my old under the hood b&m
Old Nov 21, 2003 | 08:32 AM
Slacker's Avatar
Slacker
How can I find out the exact fuel pressure for my car? And where does the gauge mount/go?
Old Nov 21, 2003 | 08:39 AM
oc_civic's Avatar
oc_civic
mcc racing
with wich gauge? the autometer OR the b&m
Old Nov 21, 2003 | 08:40 AM
Slacker's Avatar
Slacker
The B&M
