Difference in LX and EX ??
I was just curious what the main differences between the LX and EX models of the Civics were. I'm guessing engine and susp. Anything else and could you tell me what the actual diff. are?
Thanks...
Thanks...
Moonroof was optional on the LX and so was AC and Power Windows/locks
There was probably a spoiler option in there too that was standard on the EX.
I'm sure you could see most diffs at www.edmunds.com
for egs:
no lx 2dr
ex has sohc vtec engine | higher redline
moonroof standard
certain body colored exterior parts
4dr rear disck abs standard (i think) and 2dr optional
larger front disk brakes?
for eks:
no lx 2dr
moonroof standard
4dr rear disck abs optional
for em2 and ess:
moonroof standard
-only ones i know for sure at this time
no lx 2dr
moonroof standard
for eks:
no lx 2dr
moonroof standard
for em2 and ess:
moonroof standard
for 96-00 LX and EX have the same redline, and LX and EX are diff in that they LX is a 4 door only, and the EX is coupe or sedan, and has moonroof body coolerd stuff, 6 speaker stereo, cd player standard, keyless entry, and bigger engine.
Originally posted by vtecadil
and bigger engine.
and bigger engine.
As far as the 5th gen LX and EX sedans go....
Think of the LX as a DX with power options. Same 1.5 sohc non-vtec engine. But the LX has standard power windows, and locks.
Optional: Sunroof and ABS w/ rear disc brakes.
EX sedans, power everything with standard sunroof. EX sedan had standard ABS w/rear discs. Also had the 1.6 sohc vtec.
EX coupes, had power everything, 1.6 sohc vtec, but ABS and rear discs were and option.
