leaking oil - source?
Old Jul 22, 2002 | 10:14 PM
frank's Avatar
frank
frank from canada
Default leaking oil - source?
hey guys, my car is more or less falling apart, muffler rusted. oil dripping everywhere....
ok the deal is i found out the oil drips. but not *that* much. but enough for me to worry about.
i took a look underneath and basically. i did tighten the oil pan drain bolt yesterday but today some oil was still coming out.
i wiped the pan yesterday and well half of the pan is greasy.
any ideas where this oil might be coming from? the oil filter is pretty tight and so is the drain plug. can someone help me out here? is there a common place / thing that the oil leaks out from?
thanks a lot
Old Jul 23, 2002 | 12:19 AM
VTEC's Avatar
VTEC
Replace the washer on the drain bolt, and see if any gaskets need replacing.
Old Jul 23, 2002 | 12:26 AM
frank's Avatar
frank
frank from canada
i guess that *would* be the logical thing to do.....
you know how to replace the washer on the drain bolt without... umm draining the oil
i *just* changed my oil 1 week ago...
Old Jul 23, 2002 | 01:06 AM
smudge's Avatar
smudge
Check the oil sending unit.It's above the oil filter.
Old Jul 23, 2002 | 02:37 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Also realize overtightening the oil drain bolt is prolly worse than not tight. You want to tighten it down to about 17ft/lbs.
Autocross Help Page
Old Jul 23, 2002 | 02:48 AM
illgenius's Avatar
illgenius
Whackness Confirmed!
I'd check the gaskets.
Old Jul 23, 2002 | 03:35 AM
derf's Avatar
derf
Spec5
wat does it do?
i would suggest when you change your oil next time, check for deposits on the threads of the oil pan... that can cause a slow leek too
Old Jul 23, 2002 | 04:53 AM
CivicSiRacer
Originally posted by derf
wat does it do?
Overtightening your steel bolt on an ALUMINUM pan can strip the threads and cost alot of money to replace the oil pan. Just light you shouldn't overtighten the spark plugs.
Autocross Help Page
Old Jul 23, 2002 | 06:38 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
oh, youve had those grease monkeys at scrub and suds change your oil too? buncha morons.
"um...your oil pan is stripped"
"how bout i come down in that pit with my tire iron you cac"
Old Jul 23, 2002 | 06:39 AM
Fujiwara Takumi
It's my first day.
and maybe the oil filter tightness?
did you lube the oil filter before you put it on?
