si parts for 98 ex?
Old Nov 17, 2003 | 04:26 PM
loctoday's Avatar
loctoday
Default si parts for 98 ex?
can i use oem parts from a si to my 98 ex? such as intake, exhaust manifold (headers), exhaust system, springs, shocks?
Old Nov 17, 2003 | 04:29 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
i wondering the same thing about the springs,..can lowering springs made for a 99 SI fit on a 96-98 civic ex?
Old Nov 17, 2003 | 04:44 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
springs and shocks yes
intake...probably can work it to fit
header no (oh and its header, not headers...you have only 1)
exhaust sytem can be worked to fit as well (ie hit up a shop)
Old Nov 17, 2003 | 06:26 PM
Labrador's Avatar
Labrador
Loctoday,
I have a 2000 Civic EX, which is very similar to your car. I have successfully installed the following Si parts (OEM Honda) for my car: 13 mm rear sway bar, 15 in aluminum wheels, 195-55VR15 tires, leather wrapped steering wheel, mesh grille, and factory body kit (lip, side skirts, rear lip).
I also installed the Si's leather wrapped shift knob, however this requires you to purchase the Si shift lever boot, as the EX boot won't "clamp" on to the Si knob.
Also keep in mind that additional hardware (such as screws, clips, nuts, etc.) will need to be purchased if do choose to buy these parts. Since it is possible, though unlikely, that there may be some differences between the 2000 and 1998 bodies, you may want to check with the Honda dealer before you buy, so you don't get any unpleasant surprises.
Lastly, if you have the stock air intake, then do NOT buy the Si strut tower brace because it won't fit right (the stock EX intake tube has a plastic resonance chamber protruding from the top of tube which will interfere with the bar).
I hope this helps you, and good luck on your project if you decide to embark on it.
Old Nov 17, 2003 | 06:28 PM
Snoopy's Avatar
Snoopy
been there done that
Default Re: si parts for 98 ex?
header :a:
Old Nov 17, 2003 | 07:49 PM
loctoday's Avatar
loctoday
um yea, my has all da goodies on it. i just wana make it stock before i sell it
Old Nov 17, 2003 | 07:57 PM
Nelson's Avatar
Nelson
Administrator
Most engine mods won't work, but as said, you might be able to get the intake to fit.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Nov 18, 2003 | 04:10 AM
dawrenn's Avatar
dawrenn
Does that also apply to AEM cold air intakes? If so then I need to sell my Si strut tower brace.
Old Nov 18, 2003 | 05:08 AM
ZimZimma13's Avatar
ZimZimma13
Boston Dirt Dog
No with an AEM CIA you have plenty of clearence. I have that setup on my car.
Old Nov 18, 2003 | 10:30 AM
Labrador's Avatar
Labrador
ZimZimma's right; any aftermarket intake on your car and you'll be just fine because they don't have that chunky plastic chamber (aka "dead end tube") protruding from the top.
What the heck is that little tube for anyway???
