led's in air vents
Old Jul 22, 2002 | 08:42 PM
bigddd's Avatar
bigddd
Default led's in air vents
ok, i ordered a set of 4 led's from ebay and what im planin on doin is wiring them to an on/off switch and puttin the switch in those little slots next to the e-brake and puttin the led's in the air vents and such. my question is about wiring the leds, how should i go about doing it? any suggestions would be very helpful, thanks!!
Old Jul 22, 2002 | 08:44 PM
iLLuCiv99's Avatar
iLLuCiv99
bring a + wire from the battery to the switch, ground the switch as well. Ground the LEDs somewhere, and bring the + wire from the switch to the LED...
thats the jist of it...I think...its late :eh: if I missed anything, feel free to add
asiandoood's Avatar
asiandoood
sancho on the sizzide!
What do you want to wire it up to?
Old Jul 22, 2002 | 08:53 PM
bigddd's Avatar
bigddd
i dont really know what i should wire it up too, thats why i'm asking? what can i ground to? would cutting into the radio ground be Ok or no? I have a 94 Civic EX if it helps. also, can i wire in a fuse somewhere along the line or would it not really matter? thanks for the help
Old Jul 23, 2002 | 03:26 AM
derf's Avatar
derf
Spec5
think about what you want to wire it up to..... do you want to put it on a switch? or just when you turn something on, the LEDs come on too. fuse wouldn't matter on something so low drain imo.... cuz you have fuses connected to the wires that you are tapping into...
Old Jul 23, 2002 | 04:58 AM
skubb's Avatar
skubb
not that TLC sh!t either
are you talking about lighting up IN the car.
how bout connect it to vtec. it'll look like the car is heating up when it kick in
Old Jul 23, 2002 | 05:40 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
id wire it to the cig lighter, lots of power going to waste normally, so, thats proly best.
make sure those LEDs are 12v. i buy usually 5v leds and have to use a resistor to pull the voltage down a bit.
Old Jul 23, 2002 | 05:44 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
Leds? :rofl:
Old Jul 23, 2002 | 08:09 AM
FromTheBottom's Avatar
FromTheBottom
Driver of Trains
I will be doing the same thing soon...here's what I am doing:
Get one of those add-a-fuse kits (even Kmart has them) and hook the lights up to the in-car fuse box. You can mount the switch anywhere you want. Just make sure you use a good ground. I prefer the in-car fuse box because the lights can't be on without the ignition in the on/start position so they won't drain the battery inadvertently. I don't know if wiring them in series or parallel will have any effect, I haven't sat down to figure that out yet. Once my suspension is done, this is the next project so I'll have better answers then. Hope this helped a little bit. Good luck, any questions/concerns/better solutions more than welcome.
Old Jul 23, 2002 | 08:45 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
OH GOD!
We're turning into SHO! SAY IT ISN'T SO!
