Cusco MC Brace
Outxider...and all others that have it...
I found a source for the CUSCO MC brace....but they told me it was the DC2 LHD version. Will that fit my EG? They told me there's a clearance problem because they made it to clear the DC2 brake line. I dont have one that gets in the way...am I ok with this? I know you guys have the JDM version that you flipped.
well, I had the Mc stopper for rhd and had Cusco make me a Lhd prototype. The issue we had was that I measured it when I had the stock civic booster/mc and now I have the itr booster/ mc. So now the prototype is lil off. I'll update you of when the lhd mc stopper will be done.
doood, just get the dc2 rhd, flipped it and call it a day. clears the brake lines just fine. tho unless u have an itr mc, it need to cut a notch out but the teggy one like urs should be no prob. check it out...
have someone step on the brakes and observe the mc from the engine bay. you will c that the mc has a lot of play due to the flimsy firewall. the mc brace helps prevents that and provides consistant brakin. its simple yet effective mod.
Originally posted by Snoopy
someone explain to me the benefits of one of these
Hey, the DC one should work just fine, you MIGHT have to cut a notch on the bracket if your brake line hits it, that's about it.
I got the RHD version and did what Outxider did... works like a charm... I can do a little write up if you want.
Function Factor: :thumbup:
Bling Factor: :thumbup:
I got the RHD version and did what Outxider did... works like a charm... I can do a little write up if you want. Function Factor: :thumbup:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
