Please Help
Old Jul 22, 2002 | 01:26 PM
The Beav's Avatar
The Beav
i
Default Please Help
i'm trying to install some reverse indigo gauges on my 96 civic ex and i need to connect the gauge faces to the headlight power supply, somewhere under the dash, problem is that i can't find the headlight power supply, I can't find it in the haynes manual and my dash is tore apart right now so i can't go get another manual, please help, pics are much appreciated
Old Jul 22, 2002 | 01:27 PM
CivicEXR99's Avatar
CivicEXR99
Vladamirious
use your fuse in the fuse box by your panel below the dash. That's what I did.
Old Jul 22, 2002 | 01:28 PM
The Beav's Avatar
The Beav
i
how?
Old Jul 22, 2002 | 01:32 PM
The Beav's Avatar
The Beav
i
and which fuse #
Old Jul 22, 2002 | 01:38 PM
CivicEXR99's Avatar
CivicEXR99
Vladamirious
I'd have to look in my car and find out. I"m at work right now. You could do the one for the parking lights, or your low beams(i used low beams, i never use my high beams)
Old Jul 22, 2002 | 01:40 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Do you have a power tester? The stake looking thing with a bulb in it and some aligator clips at the end of a wire attached to it? You can test to see if power is running through a wire by sticking it into the wire shielding and putting the aligator clips onto a ground.
If you don't have one, there's really no way to guess and tell you where to add the wire....
Old Jul 22, 2002 | 01:51 PM
The Beav's Avatar
The Beav
i
i found a fuse box diagram, but i still don't know how to connect power through the fuse box and i can't find parking lights, but i can find low and high beams for left and right
Old Jul 22, 2002 | 03:34 PM
cobbcustomz's Avatar
cobbcustomz
i connected mine to the instrument panel fuse. i found the one labeled for the instrument panel pulled the fuse, wrapped the exposed wire around one prong of the fuse and plugged the fuse back in. I have not had any problems at all
Old Jul 23, 2002 | 06:06 AM
The Beav's Avatar
The Beav
i
i don't have a instrument panel fuse, i wired mine to my left low beam fuse, but it doesn't light up when my brights are on and this makes me unhappy, anybody got any ideas?
Old Jul 23, 2002 | 06:32 AM
cobbcustomz
Just find a fuse that will have constant power whenever the car is on. if you have a power window fuse i am sure you could tap into that one. I know thats how my one friends civic is wired up
