What Struts?
Old Nov 3, 2003 | 04:14 PM
97CivicSI's Avatar
97CivicSI
Default What Struts?
All 4 of my struts are blown and i hate even driving my
car because it is so damn bouncy. Just wondering
what stuts are better for a 97 Civic SI (EX) with an
Eibach Pro-Kit. Price wise I'm looking at either Tokico
Illumina's or KYB AgX's. What do you recommend?.
Koni's are too much right now or i would get them.
Old Nov 3, 2003 | 04:41 PM
agent87's Avatar
agent87
Need zzzzz's
Either the AGX or Illumina will be fine with your Pro-kit. I'd suggest the AGX simply because price is an issue for you. I'm sure they'll serve you very well.
BTW, you have shocks, not struts.
Old Nov 3, 2003 | 04:45 PM
ragerized's Avatar
ragerized
dc4 ownerages
koni yellows all tha way
Old Nov 3, 2003 | 04:48 PM
97CivicSI's Avatar
97CivicSI
Koni = Too Much $$$ And I need ASAP
Everyone else tells me I have struts :dunno:
Old Nov 3, 2003 | 05:08 PM
agent87's Avatar
agent87
Need zzzzz's
Definitely KYB if you want adjustable rebound damping then.
And I know it can't be everyone else...but if so, everyone else has been misinformed. h:
Old Nov 3, 2003 | 05:39 PM
Wharbone's Avatar
Wharbone
If you are trying to save money, go with the agx's. I have tokico's and I like them a lot, but they are more expensive than the agx's which are also good.
Old Nov 3, 2003 | 08:39 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
I have the KYB AGX's and like them alot. Full adjustable and easy to put on. I would say go with the KYB's!
Old Nov 3, 2003 | 08:49 PM
Wharbone's Avatar
Wharbone
What are the differences between shocks and struts? I know this has been covered, but I am still confused on this one. The service manual just calls them dampers.
Old Nov 3, 2003 | 09:20 PM
S2Kev's Avatar
S2Kev
This has also been bothering me lately so get this right.
They're actually called a shock in a Double Wishbone suspension.
A strut is what a Macpherson strut suspension has. The basic difference with the strut is that it rotates as you steer the wheels.
There is a bearing in the strut mount which sits on the top of the strut. Also a Macpherson strut suspension doesn't have a upper control arm.
A strut and shock have the same job, they're often called dampers. They dampen shocks that the springs absorb, hence the name damper.
Old Nov 3, 2003 | 09:22 PM
supapoopa's Avatar
supapoopa
Nissan: Shift_Recall
I'm running Pro-kit with AGx shocks... no complaints. :thumbup:
setting 2 front and 4 or 5 in back, will give you a near stock ride (better then stock without the body roll).
