Wet air filter?
Old Nov 3, 2003 | 11:30 AM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
I would bet that since he posted two days ago that his filter is dry by now :fawk:
Old Nov 3, 2003 | 12:15 PM
h22avid's Avatar
h22avid
Sleeper...Creeper...
Originally posted by qtiger
http://www.aquamist.co.uk/
THANKS qtiger... I learned something new today The concept concerns me though after reading their disclaimer on that site...whoaa
Anyhow, heres a quote from their site:
"The ERL Aquamist system, using sophisticated electronics to process engine-data, injects a precisely-metered quantity of coolant: not gasoline, but water, six times more effective, and freely available! We eliminate fuel-dumping, leaving your air/fuel ratio unaffected, enabling maximum power to be extracted from the engine. To ensure that each cylinder receives exactly the same dosage, we deliver the coolant in a fine mist: not only does Aquamist eliminate piston-ring damage ... it steam-cleans your engine with every stroke"
First, it states there that it is a "precisely-metered.. fine mist" which is far from straight water being sucked through your intake. So to incubus I say, it's not "like the same thing." Lets use our heads here.
According to the following quote and more prior to this on their web site, they compare the water injection to regular humidity in the atmosphere... again far different from straight water being sucked in as a result of a wet filter...
"So what is the amount of water being ingested by an engine on a wet and rainy day?
Chart shows the amount of water a 2-litre engine consumes on a typical 45% RH day, at 6000rpm, it draws in 150cc/minute of water.
On average, the engine drinks more water in its life time from the atmosphere than water injection at near WOT, unless of course you live in the desert.
Lastly, the burned air/fuel mixture contains approximately 50% water vapour and 50% Carbon dioxide, so 250cc/min of water from water injection only accounts for less than 1.6% the total output from the exhaust.
If your engine is prone to rust and seizure during a wet season, then water injection is not for you, All engines should function normally under these conditions."
Old Nov 3, 2003 | 12:30 PM
qtiger's Avatar
qtiger
My brother picked up ~20 hp using a custom-fabbed WI kit made from aquamist parts. It is activated by boost pressure rather than their fancy-schmacy electronics.
That horsepower figure comes from some math and datalogged WOT runs, not a dyno, which is why I gave approximate numbers rather than a dyno chart.
Old Nov 3, 2003 | 02:10 PM
incublinkus's Avatar
incublinkus
JDM Fan Boy
Read my post again buddy... I said water VAPOR...its understood that its a fine mist...water vapor is a saturated GAS state...
and secondly...running air through a damp cloth surface enhances the evaporation of the liquid thats condensed in the cloth, in this case the filter medium. thus, the air drawn into your engine would contain water VAPOR...not liquid water.
SO YES, IT IS KINDA LIKE THE SAME THING. :fawk: (meaning, it won't adversly affect the engine at all...it'll do it good if anything by cooling the intake charge...not that it will help on an N/A civic but still)
side note...i've heard of supra guys can run 25-27 psi on pump-gas with water injection...its awesome...but you didn't know anything about h22avid
Old Nov 3, 2003 | 02:15 PM
Nelson's Avatar
Nelson
Administrator
Originally posted by NeverBX
its made from cheese cloth, which in general is mostly used for cooking. i cant imagine why it wouldnt be able to stand the heat especially since the engine gives off more heat onto the filter on a short ram when the fans turn on.
http://www.knfilters.com/clningins.htm
h:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Nov 3, 2003 | 02:26 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
man you quote everything. :db:
Old Nov 3, 2003 | 03:40 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
aquamist owns, not too many honda guys use it though
mostly euro high boost application cars, audi's/turbo bmw's etc.
Old Nov 3, 2003 | 03:46 PM
incublinkus
JDM Fan Boy
Yeah my friend has it on his MR2
Old Nov 3, 2003 | 06:35 PM
h22avid's Avatar
h22avid
I know you said vapor and that is my point, we don't know if it's just damp or soaked... if his filter got wet, he didn't specify exactly how wet or how it got wet so again I would err on the side of caution. Does he have hai or cai? was it submerged? how did it get wet? we don't know because he was not exactly clear.
Again, I've said twice now, this being the third that a damp filter would not hurt anything "buddy"... I know we've heard this before and here it goes one more time... he never stated how wet it was or how it got wet so I prefer to err on the side of caution rather then blindly leading someone off a cliff. Is it damp or is it soaked from being submerged? We don't know so I would not just say f*** it go ahead and drive it, it wil be fine, because I don't know the exact situation
Wow there's something in this world I don't know about... imagine that just when I thought I knew everything
I have no problem admitting when I don't know something... it's an opportunity to learn... thanks again qtiger for linking us up to aquamist:thumbup:
Old Nov 3, 2003 | 08:54 PM
Nelson's Avatar
Nelson
Administrator
h:
Originally posted by K&N
DRYING HINTS
Always dry naturally. After
rinsing, shake off all excess water and let the element dry naturally.
DO NOT use compressed air.
DO NOT use open flame.
DO NOT use heat dryers.
Excess heat will shrink the cotton filter media.
Compressed air will blow holes in the element.
:fawk:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
