Tty??
Old Oct 30, 2003 | 04:47 PM
tommytoes's Avatar
tommytoes
Driver
Default Tty??
Hey I know I should be beaten to death for this question cause I'm sure the answer is yes, but just to be sure.......
Are the head bolts honda uses on the b-series motors Torque-To-Yield???
And if you flame me I guess I had it comin...
Old Oct 30, 2003 | 04:53 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
I think they are because they do stretch.
Old Oct 30, 2003 | 05:53 PM
tommytoes's Avatar
tommytoes
Driver
I THINK they are also but I need a definate answer.......help
Old Oct 30, 2003 | 06:39 PM
SRT_Andy's Avatar
SRT_Andy
YES, they ar. Just about ANY head bolt you'll ever buy will be torque-to-yeild. Just buy some ARP studs and don't worry about replacing them if you have to pull the head again.
Old Oct 30, 2003 | 08:20 PM
Paul's Avatar
Paul
Eater of Rice
Definitely get the ARP Studs, they aren't much more than OEM bolts, and they are reuseable!
Old Oct 31, 2003 | 04:58 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Best price I've seen them is at Summit.
I have a set and they are aresome. :exnbp:
Old Dec 23, 2016 | 02:50 PM
wpenno's Avatar
wpenno
ok so i dont know if this the answer you are looking for but its what I posted on another thread and what I am doing with my car, I dont know if it is a B series engine or not but it seems that honda uses both TTY and non TTY. Your best bet is to check the manufacturers manual or a Haynes manual, Chilton etc...
ok so im going to replace my head gasket on my 2001 Acura EL, AKA Honda Civic. The Haynes manual lists the following head bolt torque specs for this car
1.7L engines
Step 1.....168 in-lbs
Step 2.....36 ft-lbs
Step 3.....49 ft-lbs
1.8L engine
Step 1.....29 ft-lbs
Step 2.....Tighten an additional 90-degrees
Step 3.....Tighten an additional 90-degrees
New bolts.Tighten an additional 60 degrees
These torque specs are for SOHC engines.
From what I can tell it looks like the 1.8 SOHC engine uses TTY bolts while the 1.7 SOHC engine uses non TTY bolts
From this I would say you can NOT resuse the 1.8 TTY bolts but you could reuse the regular 1.7 bolts.
When reusing any head bolts it is important to use a tap and clean the threads in the head and a die and clean the threads on the bolts and oil the bolts before installing using a NON click type torque wrench, instead use a good quality beam or dial type and follow the manufacturer torque specs. If any binding is felt while torquing a head bolt, remove it and start again, possibly even cleaning the threads again.
As a rule is the manufacturer lists a final torque spec numerical value for a head bolt then it is not TTY and can be reused, if the manufacturer lists an initial torque numerical value followed by some additional degrees of turning then these are definitely TTY and should not be reused.
I have a 1.7L SOHC in mine and will be reusing my original head bolts after they are cleaned up and oiled.
Just my 2 cents
