Head swap
Old Oct 21, 2003 | 03:00 PM
94typerhb's Avatar
94typerhb
Default Head swap
i was wondering if i put a 2001 gsr block on a 99 CTR head would it run faster being that the ctr block is a 1.6 compared to the gsr block being a 1.8? or should i keep my ctr the way it is now by not switching the head? any comments will be appreciated.
Old Oct 21, 2003 | 03:15 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
you would get more power out of it. A lot of people put B16B/B18C5 heads on B16/B18 blocks to gain hp. The cams alone would give you a good deal of power increase on an N/A application.
Old Oct 21, 2003 | 04:29 PM
EKHatchRacer's Avatar
EKHatchRacer
why dont you just get a type r head. from there you could make make it a type r cause gsr's and type r's have the same block
Old Oct 21, 2003 | 04:30 PM
westcoaststyle
Ummm.. he is getting a type r head. Read it again. GSR block, CTR head. h:
Old Oct 21, 2003 | 04:31 PM
EKHatchRacer
i meant ITR head. im not sure about the compatibility issues between a 1.8 block and 1.6 head
Old Oct 21, 2003 | 04:33 PM
westcoaststyle
I'm thinking cause he already has the B16B motor and wants the extra .2L... not sure though...
Old Oct 21, 2003 | 05:12 PM
Kai's Avatar
Kai
Rotorphile.
If he already has a B16B, all he needs is the crank and rods from a B18C. That should be way cheaper then the whole block, or a little closer (but still cheaper) if he gets aftermarket rods.
Old Oct 21, 2003 | 07:38 PM
alllooksnnogo's Avatar
alllooksnnogo
Just another import lover
Why change the block??? If you have the the B16B like me looks into something like this:
http://www.inlinefour.com/spoon18lstro.html
I am :thumbup:
Old Oct 21, 2003 | 07:49 PM
Kai's Avatar
Kai
Rotorphile.
What's the point in buying a Spoon kit when you can use a factory B18A/B rod and crank combo or a B18C rod and crank combo? Both will give around 1800cc, just without the Spoon name.
Old Oct 21, 2003 | 09:18 PM
Snoopy's Avatar
Snoopy
been there done that
but its spoon! :eek3: h: :jdm:
