headlight bulb replacement
Old Oct 17, 2003 | 07:11 AM
Ranger's Avatar
Ranger
Default headlight bulb replacement
Do I need to remove the entire headlight in order to replace the bulb? I have a 2000 Civic and it looks like I'd either have to remove the entire headlights or remove some stuff in my engine compartment to get access to the rear of headlights to change the bulbs... is there an easy way?
Old Oct 17, 2003 | 09:10 AM
NoRiCeHeRe's Avatar
NoRiCeHeRe
Are you replacing the front or rear light bulb?
Old Oct 17, 2003 | 09:31 AM
96GreenCivic's Avatar
96GreenCivic
Hope you have small hands. It's not that bad. On the driver side, you're gonna have to remove the power steering resevoir. Just slide it out of the harness and move it to one side. Other then that, you won't be able to see the back of the headlamp. Just have to take off harness, remove rubber gasket, find spring clamp, remove bulb and reverse to install. You don't need to take out the headlamp to replace any bulbs. If you do that you'll have to remove the entire bumper. Just reference your manual.
Hope that helps
Old Oct 17, 2003 | 09:49 AM
NoRiCeHeRe's Avatar
NoRiCeHeRe
Hope that helps
:werd:
Old Oct 17, 2003 | 06:04 PM
swissarmyca's Avatar
swissarmyca
Took me some time to replace my headlight bulbs because there was very little clearance behind the headlight unit to pull the darn connector out. Finally did it. Expect some scraped hands and fingers :bigok:
Old Oct 18, 2003 | 04:55 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
I got used to taking the bumper off.
takes like 2 minutes.....
Old Dec 21, 2007 | 09:24 AM
llltrunkslll's Avatar
llltrunkslll
I agree about having small hands. I can't fit them inside more than enough to just wiggle my finger by the connector.
Old Dec 21, 2007 | 01:55 PM
minh47em's Avatar
minh47em
i hate changing mine, least its not a monthly thing....
Old Dec 22, 2007 | 11:39 AM
Civic2Scooby's Avatar
Civic2Scooby
I just take the bumper off...it takes less time than trying to figgle fuck with the lights in the car.
Old Jan 11, 2008 | 06:29 PM
dowyboy's Avatar
dowyboy
i had the same troubles here.. i moved the powersteering reservoir a little... but i can barely take it off the harness. im not really in a better position... whers the damn clamp!!??
