knocking in rear strut assembly! :(
Old Oct 13, 2003 | 06:28 PM
alllooksnnogo's Avatar
alllooksnnogo
Just another import lover
Default knocking in rear strut assembly! :(
k guys....over the past 2 weeks or so I've noticed a slight knocking noise in the rear passanger strut assembly. Its getting pretty anoying I'm guessing its the CA bushings seeing as how my car is around 100k and its just that time Also I took my wheel off and checked them, they look pretty crappy!! Would there be anything else that might be causing my problem?
K part two
If in fact my rear bushings are shot and I have to replace them, will I be able to replace just the bushings pressing the old ones out or will I have to replace the whole control arm? If so how much do you think this venture will run me??
:thumbup: thanks boys
Old Oct 13, 2003 | 07:49 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Press them out and put some urithane ones in there. :thumbup:
You can get the ES kit for just the rear LCAs I think.
Old Oct 13, 2003 | 08:46 PM
alllooksnnogo
Excallent!!! West thanks man. Your always around to help a brotha out I will check the ES kit out now on the net. Thanks for answering another question of mine as to what PU bushing kit I should purchase. I'd rather not go thru this again so I think I will take your advise and go for the urithane bushings. I will still have to take them to my local honda dealer I believe. They will have the proper machine to press them out right?? You can't just DIY can you??
Old Oct 13, 2003 | 11:56 PM
dlh1999's Avatar
dlh1999
Runs with scissors.
You're sure it isn't a blown strut in the back? Sometimes they make a knocking type sound when they're blown...:dunno:
Old Oct 14, 2003 | 05:09 AM
alllooksnnogo
Ya that could be true bro but I don't think so due to the fact that:
One>their Koni yellows
Two>I just put them on at the start of the summer
However stranger things have happened
The bushings have to be replaced anyway so we will know soon enough!!
Old Oct 14, 2003 | 12:55 PM
alllooksnnogo
K....I called my local Honda shop and they told me that they would not install aftermarket bushings for me. I asked about regualar rubber and he told me that the entire CA had to be replaced.....nice I said "screw that"...so I went to a spring shop down the way and he told me that he could install the LCA urithane bushings for Roughly $200 CDN parts/labor.
Is this a moderately good price for just the LCA's or should I shop around????
Matt
