neuspeed or H&R
Old Oct 15, 2003 | 07:12 PM
tommytoes's Avatar
tommytoes
Driver
I'm sure somewhere, Some blowjob has done that.
Sad but true.
Old Oct 15, 2003 | 07:36 PM
toadolson's Avatar
toadolson
The One And Only!!!
Originally posted by tommytoes
actually I will really be going for the stiffer ones.....
since SCCA might be something I'd be looking into once I move to cali...
thanx yous guys..
If your thinking of doing a little SCCA stuff, I would consider GC coilovers rather than a set spring. Said i was running neuspeeds right now. Doing a whole new suspension this winter. GC customs with a 450 rate front and 500 rate rear. Koni yellow with a re-valve if money is not a problem. You can get new springs rates at anytime for $50 bucks a pop. To me thats not bad. Just an idea.
Old Oct 15, 2003 | 07:38 PM
randomtask77's Avatar
randomtask77
Wanderer
I think that they're pretty much the same. But I did notice that the H&R's tend to be a little lower as compared to Neuspeed's springs.
Old Oct 15, 2003 | 07:39 PM
tommytoes's Avatar
tommytoes
Driver
actually I was looking into the skunk2s for that scenario cause they alos have different rates for also 50 bucks a pop...up to 10kg/mm(559lb/in)
Old Oct 15, 2003 | 07:44 PM
toadolson's Avatar
toadolson
The One And Only!!!
Yes, i thought of the same thing. But with skunk2, they are set rates( 6kg-334lb/ 8kg-448lb/ 10kg-559lb/ all the way up to 18kg-1000lb). The GC are at a rate of 50lb per spring. (300-350-400-450-500-etc.) Better fine tuning for your weight of the car and power produced.
Old Oct 15, 2003 | 07:49 PM
tommytoes's Avatar
tommytoes
Driver
Well I never looked at it that way..makes sense...
I also knew that there was an 18kg/mm rate but chose not to even mention it cause it would be absurb to use that kinda spring rate on any honda.
Old Oct 15, 2003 | 07:56 PM
toadolson's Avatar
toadolson
The One And Only!!!
I liked the Skunk2 for the only fact of the duel locking ring on the coilover. Then i called GC and they explained how there adjustment ring works. Sold me there and more choise of spring rate. Like i said, just an idea.
Old Oct 15, 2003 | 07:57 PM
Wharbone's Avatar
Wharbone
could you just use gc custom springs without the coilover sleeves or would that just suck?
Old Oct 15, 2003 | 08:05 PM
tommytoes's Avatar
tommytoes
Driver
well the skunk2s you can get in different heights(and I think the GCs as well), so in theory you could just select the height (of the spring)...
But you would have to work out what the compressed height would be and probably make a custom seat for the bottom of the spring to stabize it.
