Engine Trouble !
Old Oct 13, 2003 | 04:17 PM
civicBite's Avatar
civicBite
Default Engine Trouble !
Alright here it goes. My car has been having troubles starting for a while.. probably a little under a month. It started off with the engine just taking a little longer than usual to turn over, but it would still be fine. Progressively, it's been getting worse and worse until finally just this past weekend, I had to push it and pop the clutch to start it.
Now I checked the battery for voltage and that is fine, so I don't believe that's the problem. I've pushed together all of the wire connect points, and that didn't help. The nengine still tries to turn over, though, and when I turn the key, the engine will make the sound right before it turns over, and the belts turn a little bit, but there is a long pause (3-5 seconds) in between each of these attempts to turn over.
With all of this, I figure that it's the starter that needs to be changed. Just today (for the first time) the engine made a clicking sound when I tried to start it, and I opened up the starter and it does look a little worn out (don't know if it's ever been changed since I got it new in '93. Well these are the symptoms, any diagnosis would be very much appreciated. Thanks!
Old Oct 13, 2003 | 04:38 PM
Wharbone's Avatar
Wharbone
you could go to autozone and have them test the starter and even have them re-check the battery.
Old Oct 13, 2003 | 04:48 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I say starter too. AZ will test it for free. Take it there.
Old Oct 13, 2003 | 05:23 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
putting my money on the starter..
Old Oct 14, 2003 | 06:24 AM
civicBite's Avatar
civicBite
Thanks for the replies, guys. just dropped it off at my mechanic a few minutes ago.. he's gonna call me back in an hour or so. We'll have to wait to see what the verdict is!
Old Oct 14, 2003 | 06:52 AM
Wharbone's Avatar
Wharbone
mechanic? why didn't you take it to autozone and have them test the starter?
Old Oct 14, 2003 | 07:08 AM
westcoaststyle
:doh:
Dude, if you can't even take your starter to AutoZone to have it fixed, you don't deserve to drive your car.
