I learned something today - Mounts
Old Oct 12, 2003 | 07:24 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Default I learned something today - Mounts
The D16Z6 upper cam mount is the same mount as the Bseries' use. h:
I worked on a guy's car (replaced his axles, put in prothane mounts) and thought he got the wrong cam mount inserts. After popping his hood and comparing it to the Bseries mount I have, it's the same.
I had no idea. I know the D15B7 one is different.
I just thought I'd share if anyone is doing a Bseries swap on a 5th gen EX/Si. You won't need that mount from the swap.
:thumbup:
Old Oct 12, 2003 | 08:10 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
im using stock mounts on my DX hatch for my b20 motor h:
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
oh your talking about cam mounts h:
Old Oct 12, 2003 | 08:12 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
the internat stuff i believe is different between the b and d series for that mount.
when you go rid of the rubber did water or liquid come out of the mount?
if you drill into the rubber of b series mount. there is liquid in there. i don't think the d series are the same in that sense. i could be wrong.
also. i thought the d series mounts only had 2 holes for the studs coming up and no third hole for the bolt going down. the d series had all 3 holes?
Project EVA - The Track Package
Project EVA
Old Oct 12, 2003 | 08:31 PM
westcoaststyle
hmm.. lost my post in the db optimizing. hmmpf
Don't know about liquid because we decided not to do that one due to the lack of a press.
The Dseries mount did have 3 holes: 2 for the studs and 1 for the bolt that screws into the motor itself.
I shouldn't be telling you this either... you won't buy my mount. :happysad:
Old Oct 13, 2003 | 10:10 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
the d-series mounts are also liquid filled to supress the vibration from the engine.
