Putting together my DIY ground kit
Cone Basher
So far I've purchased:
10 ft. 4gauge Monster ground Cable
Zip ties
12 4gauge ring connectors (crimp-on)
I've got a few questions about putting this together:
Soldering
When I asked about soldering this stuff, the guy at the audio store told me that I'll need a cheap butane torch ($10) to melt the solder and run it into this hole:
Can I accomplish this with a regular soldering iron? Crimping will work, but to make a good connection, I'll need to solder AND crimp. (obviously, I'll be removing the hard yellow jacket). Is there a certain type of solder I should use? (this is probably one of the first times I've soldered)
Heat Shrink
I found heat shrink that is 1/2" in diameter, and shrinks to 1/4". The 4guage cable is 1/2" in diameter. Can I use this heat shrink?
Dielectric Grease
Is it alright if it comes in contact with the rubber heat shrink?
Thanks,
LX4CYL
Zip ties
Soldering
Heat Shrink
Dielectric Grease
Thanks,
LX4CYL
Re: Putting together my DIY ground kit
soldering is easy buddy, do some test spots first, to get the hang of it, what ur doing is definitely gonna make great connections just remember the bigger the connection to the frame the less resistance is created, as for types of solder make sure u get one that is meant for electronics, it will say so on the outer package, as for soldering iron probably wont work unless it gets REALLY hot id say just use a propane torch or mapp gas, and dielectric grease wont hurt a thing. ur on ur own with that heat shrink, i dont know
Cone Basher
Re: Re: Putting together my DIY ground kit
BTW, where should I get all of the bolts needed to attach the ground wires to certain unused threaded holes on the engine block and head? I already know that one of the bolts that I need is the same one that holds the plastic bit that organizes the spark plug wires on the head. They fit here:
Cone Basher
Yep, I did well today
I cut away the very center of the ring connector terminal so that it will close tighter when I crimp. Then I used my propane torch to lay down the solder. After that I used the heat shrink (I got some at Ace Hardware) to create a nice looking ground cable. The solder is perfect!
Anyways, I have a few question about grounding points:
https://www.honda-acura.net/forums/s...threadid=74009
How much of that 10ft of wire did you use?
Any left over?
I was planning on doing the (+) and (-), so i wanna know how much wire to buy. How did you spend on the wire?
Any left over?
Cone Basher
Any left over?
Any left over?
I got it for $2/ft., but you can get it much cheaper at sounddomain.com :thumbup:
