No Turn Signals
Old 05-03-2003, 01:45 PM
Phat8186
Phat8186's Avatar
Default No Turn Signals
I have a 96 accord and i know that when you dont have the hazard switch in you wont have any blinkers. Well I lost my turn signals today and I dont know how to get them back I checked all the fuses they are all good. I do have the headlights and the jdm corners working but there is no turn signal at all. could this be cause when I hooked up the jdm corners I took one buld out from each side. please someone help me.
Old 05-03-2003, 02:31 PM
AcuraFanatic
AcuraFanatic's Avatar
Who needs turn signals. Just stick your hand out the window.
Old 05-03-2003, 02:52 PM
EliteAccord
Banned
EliteAccord's Avatar
Did you check the 7.5 amp turn signal fuse under the dash? And the 15 amp hazard fuse in the engine bay?
Old 05-03-2003, 05:59 PM
95AccordEXR
95AccordEXR's Avatar
when did they stop working?
Old 05-03-2003, 07:24 PM
Phat8186
Phat8186's Avatar
they stop working today I think i cant remember if I used them yesterday, I have checked all the fuses and they are all still good I will double check tomorrow though also. Is there any other good insite that anyone can give me so when I check it out some more tomorrow
Old 05-03-2003, 10:12 PM
EliteAccord
Banned
This sounds stupid but did you check your turn signal bulbs to make sure they aren't burnt out?:fawk:
Old 05-03-2003, 10:56 PM
Nightshade
un-Touch'd krew
Nightshade's Avatar
So since we all know the turn signals won't work if the hazard button isn't installed..........is the hazard button fully hooked up?
Connection may have come loose.
If not is the switch burnt out?
Seems logical conclusions to me.
Old 05-04-2003, 12:02 AM
96JdmAccord
Im So JDM
96JdmAccord's Avatar
OK correct me if im wrong. On a Stock 94-97 accord you have 2 bulbs in your corner lights. Im pretty sure one bulb does the blinking and the other bulb stays on. The Real JDM stanley corner lights have one bulb insert. You said you put one bulb in the corner lights. Now I just got a pair of JDM headlights/corner lights. The only bulb/corner plugs that will fit is the the one that stays on all the time. Unless I got some special pair that does not let the blinking bulb/plug fit in it.
So basically you put the blub/plug that stays on fully and left the one that does the blinking out? Am I correct? That is my guess. Im pretty sure it is this cause or the post above.
Jon
Old 05-04-2003, 12:51 AM
EliteAccord
Banned
Jon
Actually the 94-95 corner bulbs is the one where only one blinks and the other stays on. In the 96-97 both stay on. The 96-97 front bumper turn signal is bigger then 94-95 because DOT requires that turn signal be visible from the front and front right side.
You can just swap the sockets by cutting off the socket on the one that blinks and rewire it to fit.
Old 05-04-2003, 06:25 AM
99accord
www.poksquid.com
99accord's Avatar
i'm lost....
