no start please help!
Old 03-31-2003, 03:47 AM
accordtuner
Banned
accordtuner's Avatar
Default no start please help!
hey guy,
i got an on and off problem, it would start for a couple days but run ruff, then the next few it wont start (turn over all the way) no spark at all. could the ignitor work one day and not the other? could it be the ignitor? i already checked the wires, cap, rotor, plugs.
thanks,
joe
Old 03-31-2003, 05:41 AM
Temporary
Temporary's Avatar
Sounds like what was happening to my car last week. Turns out i needed a new starter. My car would start fine one moment, and then i would try to start it again, and nothing would happen. If your car doesn't start, try having someone tap the starter while you try to start the engine. Hope this helps!
Old 03-31-2003, 06:26 AM
accordtuner
Banned
starter is brand new, it has spark.
Old 03-31-2003, 07:43 AM
HondaFanatic™
Guest
Posts: n/a
:werd: I was thinking starter.
Old 03-31-2003, 08:41 AM
Kabuki
Kabuki's Avatar
Default Fuel
Check your fuel pressure.
Old 03-31-2003, 08:53 AM
95AccordEXR
95AccordEXR's Avatar
distributer?
Old 04-02-2003, 08:47 AM
accordtuner
Banned
i jus swapped distributors, checked the coil, ignitor, where is the main relay located on a 97accord lx 2.2, what else should i check ??
Old 04-02-2003, 09:07 AM
green2dr
green2dr's Avatar
could be the main solinoid. When you turn the keys to the main position do u hear hum under the dash? The hum is the main solinoid. It sends information to start the fuel lines i guess. I had that problem with my prelude when the weather got really hot. The solder expanded in hot weather and would not relay the electrical response. I just resodered all the points and it works perfectly now
Old 04-02-2003, 11:13 AM
Temporary
Temporary's Avatar
Actually, I heard from a mechanic when i took my car in for a new starter, that the hum that is heard when the keys are turned is the fuel pump itself.
Old 04-02-2003, 11:33 AM
accordtuner
Banned
where is the main solenoid located? how do i check this?
