Adjusting Hydro Clutch Engagement
Stupid Hurts
Is it possible? My Clutch engages 1 inch from full pedal release, and is at full engagement 3/5 push.... any way to change this so the pedal engages a little bit further down?
RedRexDX,
Yes, it should be possible...the process should be delineated in your shop manual.
I took a look at the clutch MC on the wife's 1996 Civic when I had a minute this morning, but didn't see what I was expecting...so the adjustment might be at the slave cylinder...
See if there is a pushrod in the slave that attaches to the engagement lever on the tranny...if there's no pushrod on the master, you would have to do the adjustment here I'd think.
Ah, there we go, I just looked at the shop manual for her car...the pushrod comes into the cabin...so if you want to mess around with it...that's where to start...
Bogatyr
Bogatyr
just make sure you dont go too extreme with the adjustment.... if you set it too high you are going to burn the clutch, if you set it too low it may not engage correctly... also, when you set it high, in time it will slowly go down until you cannot adjust it anymore then you will need a new master cylinder, which isnt too expensive
You can adjust the pedal to rod backlash(the amount of pedal movement before it contacts the rod) but you CAN NOT adjust a hydraulic clutch. Or anything hydraulic, brakes, power steering etc...
