1999 Honda Accord MAIN RELAY LOCATION?
Old 09-12-2008, 07:52 AM
RichKing
RichKing's Avatar
Default 1999 Honda Accord MAIN RELAY LOCATION?
Ok I know that its in close proximity to the steering column under the dash but there are 2 visible location of relays.... One on the right (Radio Side) and one on the left (Drivers Door Side)..... Which one is the main relay....????
I have found a fix for the relay which is nothing more than a simple resolder of existing connections.... I just want to make sure that Im pulling the correct relay before I go through the work of getting it out... The one on the right side (towards the radio) looks pretty easy to drop down and get at.. The Left side looks like a bit of a bitch.........
Need some quick answer if possible..... Im just about ready to pull it out........
Below is the website that confirmed that the Main Relay is under the dash... Dont forget its a 1999 Accord... the exact location is hard to determine by the position shown in the graphic.... Obviously there must be somebody that has done this repair on the message board.. I just dont want to pull the WRONG Relay ............
http://techauto.awardspace.com/mainrelaydefine.html
