92 Acura Legend
Old 08-22-2008, 08:18 PM
dnice63
dnice63's Avatar
Default 92 Acura Legend
I have a 92 Legend Coupe, I can start the car let it run for a while the cut it of it will not start back up. Sometimes for a couple of hours sometimes for a couple of days. I have try changing the main relay(new), the crank sensor(new), starter(new), even check the cam shaft sensor. I am still having the same problem. Any help? Thank You.
Also does anyone no where the diagnostic hook-up is in this car or is there on on this model?
Old 08-23-2008, 04:48 AM
L3GKANG
Prezz of ACURA-HOLIKS
L3GKANG's Avatar
do get a check engine light? if so you can run the codes with a chilton book but i try to get the big gray book off ebay its from the dealership but you cant buy it.
Old 01-18-2009, 11:29 AM
red legend
red legend's Avatar
i think it is from the fuel pump
