18" Wheels
Old 11-28-2002, 08:31 AM
1999civicEX
9" member
1999civicEX's Avatar
Default 18" Wheels
Anyone have any problems with 18 X 7.5 Wheels on their civic? My tokico suspension lowered it 1.5". Is there a good chance i'll rub?
Old 11-28-2002, 08:35 AM
toadolson
The One And Only!!!
toadolson's Avatar
There is a 96-98 civic ex with 18 on a 3" drop. It looks so sweet
with the tires tucked in the fenders. The guy told me he went through 2 fenders trying to get everything right. Just the way his looked, it's definatly going to rub.
Old 11-28-2002, 08:36 AM
randomtask77
Wanderer
randomtask77's Avatar
More often than not, it will. If you have a +42mm offset and you have a 215 size tire, then you will be keeping the rubbing at a minimum. But if you still have about a finger gap between the tire and fender, then probably not...
Be forewarned, many will advise you against the 18's...
Old 11-28-2002, 08:49 AM
1999civicEX
9" member
my dilema is even with my 17"s and the 1.5" drop, theres still some gap i'd like to get rid of.... damn they need to make a 17.5" rim...
Old 11-28-2002, 08:55 AM
EX R8ED
is whipped
EX R8ED's Avatar
Don't you rub already? You'll definitely rub with the 18's. You could try rolling the fenders. Or better yet keep the 17's and get a different suspension that lowers a little more. Or if you wanna know what I'd do. Sell your current wheels and suspension, buy some nice 15's or 16's and slam that biatch but hey, thats just me :thumbup:
Old 11-28-2002, 08:59 AM
huviduc
huviduc's Avatar
i have 17s on a 5th gen and i have no wheel gap in front. about half my tire is hidden and i rub when i turn the whole way to the left or right. other than that im good. id have to say 18 are to big. unless you keep it ridin pretty high.
Old 11-28-2002, 09:20 AM
ur31337
Colby
ur31337's Avatar
My friend Paul has Motegi MR7s on his 2000 SI. 215/35/18s and he had to roll the fenders.
Old 11-28-2002, 11:09 AM
randomtask77
Wanderer
When I had 18x7.5" with 215/35's I had about a finger gap and I would still rub when I hit bumps and small dips. :angry:
A good alignment would also help in aiding to prevent rubbing... If you're camber is all wrong (like mine was) then you'll definitely experience some tire rubbing.
Old 11-28-2002, 11:42 AM
1999civicEX
9" member
i think i'm gonig to stick with 17"s, you guys convinced me. I dont experience ANY rubbing currently, my bump stops take care of that.....my suspension is very tight, so that helps in preventing the fenders rubbing. I'd rather not bend the fenders, i like to keep things hassle-free.... Now i just need a new set o' 17"s
Old 11-28-2002, 11:47 AM
randomtask77
Wanderer
Good luck shopping for your new wheels... What did you have in mind (style, color, etc.)?
