crankshaft position sensor problem help!!!
I have 96 acura TL, I just change out the spark plugs then 2 days later then
engine is stalling and can't rev over 3000 rpm the engine light is on, so i
took it to autozone to pull up the code. then it pull up 6 codes one of them
is po335 (crankshaft position sensor) so do i have to change out the sensor?
but its $350 for the sensor!!
Lord Vader Moderator
What are the other 5 codes for?
But do you know what they read? You mentioned one is for crankshaft position sensor, what about the other 5?
crankshaft position sensor replacement help!!
Im having problems with my 96 TL, I have to replace the crankshaft position sensor. does anyone know where is it? and how to replace it?
Before changing the sensor, you need to find out what the other 5 codes are for. 99% of the time, it is NOT the crankshaft position sensor and is something else. You can change it if you want, afterall, it is your money.
