Fuel pump Cut-Off switch wiring, Where do the fuel pump wires run through?
Old 11-13-2006, 07:49 AM
Quick Silver
Vroom Vroom..!
Quick Silver's Avatar
Default Fuel pump Cut-Off switch wiring, Where do the fuel pump wires run through?
I want to install a hidden switch to cut off power to the fuel pump as added security for my car when parked but have no idea of where the wires to the fule pump run through.
can anyone shed some light on this? I really dont want to start looking under the carpet of the whole cabin to find it h:
Thanks
Old 11-13-2006, 02:47 PM
LateApex
Track Day Club
LateApex's Avatar
The main relay for fuel management is located just above the ECU behind the driver's side outboard kickpanel.
Old 11-14-2006, 05:24 AM
kd5dbl
kd5dbl's Avatar
Another easy way is to use the starter interrupt feature that's part of the clutch switch. You know, you can't start the car without the clutch pushed down?
Just tap the wire going to the clutch switch and put yourself another switch under your seat. It's not foolproof, but what is really?
