RE: Exhaust smell in cabin.
so i cheked everything out and saw a small crack in the header right where it bolts up to the head and i think its because the motor mounts are bad and need to be replaced. i noticed everytime i revved to high rpms the motor would rock back and forth really crazy and the only thing i can think of is bad motor mounts to cause the engine to rock like that, therefore putting stress on the header and cracking it leaking exhaust into the engine bay and into the cabin through the air ducts. what do u guys think of my hypothesis? i know the last post i did on the same subject got only one reply so i narrowed it down and maybe someone can tell me if the motor rocking back and forth on revs IS caused by bad motor mounts and messed up exhaust manifolds to leak exhaust into the cabin....................any help appreciated.
just get the exhaust fixed. exhaust leaks gets into the cabin. the motor mounts didnt do it. alot of hondas have bad mounts. not knowing which accord u have, but if its an older one, there is a dogbone shaped one at the front of the car, by the radiator, that goes bad.
